I have a friend that drew a pattern to size on a large poster board paper and wants me to cut them out. My question is what would be the best or easiest way to get them traced/copied into aspire. Drawings are too big for any scanner.
Shopbot probe has done well for me in the past.. (2D)
Rik
He drew this with a sharpie otherwise I would use our probe. This is on flat paper.
Depending on how critical the pattern is you could take a pict of it (far away is best) and then trace from that.
Glue it to 1/8"/1/4" hard board and use the probe.
Do not rely on a smart phone for pics...the lens is too small and there will be a lot of distortion...you'll have to start all over again.
I've done it with a regular camera with good results before. Guess that depends on how accurate you need it to be!!
Probe would be better.
Rik
It's possible to probe a drawing?
Thanks Brady...that is what I was thinking I would have to do. I was hoping for a better way that was faster than making a template with wood.
Photo done with a good camera.
Good. Fast. Cheap. Pick two.
Hopefully you are charging for digitizing the panels as a separate line item than cutting.
What is the overall size of the panels/parts? How close to the original part(s) does the copies have to be?
