I received this email after I had sent some modified drawings to a client. For all the ones who give you a hard time, then there's this:
Thank you David for the quick turnaround.
The 8" version looks perfect. With the 9" version, I see two drawings, one with the speaker pocket and another with the electronics pocket. I'm not sure what that is about but if both pockets were on the same drawing like the 8" version, that would be perfect.
Honestly, I have not used any of these drawings to cut any boxes myself. If I did, here's what I would have to do:
1. Drive to Home Depot.
2. Rent a van for $19.99.
3. Purchase a 4' x 8' sheet of 3/4 MDF for almost $40.
4. Load it into the van.
5. Drive the van to the tech shop.
6. Unload the wood and drag it into the wood shop.
7. Reserve a time on the Shop Bot.
8. Drive the van to the gas station and top it off.
9. Drive the van to Home Depot.
10. Drive my car back to the Tech Shop that day (or whatever day I could get a reservation).
11. Load the wood onto the Shop Bot, secure it.
12. Sit there and babysit the thing for at least an hour while it cuts the pieces.
13. Unsecure the wood piece and drag it over to a bench.
14. Hand cut every tab from every piece (at least 4 tabs per piece) to remove them from the large piece.
15. Check out the router table, router kit and router bits kit.
16. Set up the router with a flush trim bit.
17. Grind off all of the tabs.
18. Clean up all that mess.
19. Check back all of the tools.
20. Drive home.
OR... I could
1. Call you.
2. Drive to your shop.
3. Hand you 80 bucks, pick up the pieces.
4. Drive home.
WAY better option. [IMG]file:///C:\Users\David\AppData\Local\Temp\msohtmlclip1\01\ clip_image001.png[/IMG]
