Thread: MTC.sbp - CHECK_MTL subroutine
    Dec 2015
    New Jersey
    Default MTC.sbp - CHECK_MTL subroutine
    I was looking at MTC.sbp and can't figure out why CHECK_MTL subroutine is there. It doesn't seem to do anything. No matter what, it's going to set &z_adjust to zero.
    First line is commented out. Second line sets &zshift to zero.
    If MSGBOX answer is NO, then &z_adjust = 0 * 0
    if MSGBOX answer is YES, then &z_adjust = 0 * 1
    CHECK_MTL:
    'If &zshift = 0 Then GoSub MTL_ERROR
    &zshift = 0
    if &zero_to_bed = 0 then GoTo doaskbed
    if &zero_to_bed = 1 then GoTo doaskbed
    MSGBOX(Did you Zero to bed? ,YesNo,ZERO BIT?)
    doaskbed:
    if &msganswer = NO then &zero_to_bed = 0
    if &msganswer = YES then &zero_to_bed = 1
    &z_adjust = &zshift * &zero_to_bed
    return
    Apr 2007
    Marquette, MI
    Scott...
    I didn't write the code, but my guess is that it is in there for compatibility with the ShopBot Link which uses the "&zshift" variable. I would imagine that when in use the comment may be removed from one line and others would rem'd out
    GCnC Control
    Servo Controller Upgrades
    Albert Einstein
    Dec 2015
    New Jersey
    Thanks. I think I'll just delete it from my version - clean things up a bit
