This was the supplier I ordered it from. As you can see in the ad, it has the connector we would like for plugging it right in, but according to what they told me, the newer ones from the factory now have what was shown in my video. If you search for HQD 3.5KW, you'll come up with several suppliers. At the time I ordered it, there was a small discount and they had the least amount of shipping. Others may be better now, or prices may vary depending on when you look. Be sure to check the options and get the desired collet size. I wanted an ER25, so it was compatible with what I've been using for collets. There are some 2.2KW ones, but they have an ER20 collet. The nose cone is the same size as the HSD, so if you have a dust foot that clamps there, it will fit. I've got the newer SB dust foot and it fits up just the same.
There's a simple wiring diagram on the inside of the cover (for 220v or 380v) that I used to match up with the VFD's marked terminals.
As far as parameters, I just jumpered the factory connections to bypass the thermistor so that the VFD saw a closed circuit. I tried changing the parameter that appeared to be for that (053), but I couldn't get it to work. I didn't see a parameter value for 'disable' and setting it to NO didn't work, so jumpering it was the fix. Note, I have the big honkin' VFD in a box, Yaskawa V7-4X.
They did ship quickly though with DHL. Had it in hand in about a week.
