Results 1 to 6 of 6
Thread: Optical registration on ShopBot
    Aug 2011
    Oakland, Ca
    Default Optical registration on ShopBot
    Is there any way to modify a ShopBot PRS Alpha for Optical Registration.
    We print and laminate in-house. And sometimes we need to rout to shape, but have to manually register the mounted material prior to routing. It can be tedious and inaccurate.
    Is there a solution with ShopBot and V-Carve?
    John,
    Not to my knowledge using SB3. You could however keep the SB hardware and change the controller to WinCNC and purchase their OptiScout plugin.
    RE: https://www.wincnc.com/mapp_vision.php
    Aug 2011
    Oakland, Ca
    Thank you Brady.
    Oct 2013
    3rd rock
    Would a cross-hair laser not work? They can be mounted to any machine.
    Tah-Dah
    Quote Originally Posted by 8Ball View Post
    I would think that anything laser would be too coarse for the OP's requirements.
    Jun 2018
    Pennsauken, NJ
    Shopbot has a laser pointer in thier shop. Laser Pointer
    #006326
    $ 150.00 USD
    IDK about the software mentioned but wouldn't you have to let the machine scan the full material to be routed to find the registration points? I have an inkling of what the OP wants to do and I'd think that manually moving to your marks might be the easiest solution - though I could be way off.
