The considerations we most commonly discussed when asked which machine is best are; how much space is available, what does the budget allow and what is the intended product, will it be a specific product that only requires a smaller machine or will the tool be used for a more diverse selection of products or be a larger size for the most part. These are the most typical considerations in deciding which form factor is best when purchasing a ShopBot, whether it be a full size PRS or a Buddy.
The Power Stick was originally a part of the Buddy design. In fact, the first few shipped had guide bars with power stick wheels and ball rollers, as well as, cam handles for releasing the table so a power stick can be installed. Unfortunately, fabrication of power sticks wasn't up to speed before shipping these tools and the power sticks had to be made available later. The latest Buddy tools were designed to improve upon these tools by making them much more rigid than their predecessors. One way this was done was to use a single sheet of 1/4" steel for the main deck instead of many individual parts bolted together that required lots of finessing to get them aligned properly. This also had the advantage of using laser accuracy in cutting of holes for the power stick wheels and other critical parts. These changes made the alignment of the power stick much easier and reliable by removing the many variables that multiple parts created. The new deck also allowed us to add rollers to the center under the cutter instead of just the outside edges, providing much more support surface. These rollers support the work holding surface better by spreading the load out and help to prevent the surface from being pushed down when plunging or pulling it up when using an up cup spiral. Another big change was to go to a power sitck that is 3 times wider and almost twice as thick. This allowed the wheel base for the power stick to be increased considerably and providing a powers stick with a higher load capacity and more surface to mount the work or work surface to.
Other changes include changing the orientation of the power stick motor, making it more rigid and unlikely to twist under load. The cam handle was simplified and the release handle moved to the side of the table where it is easier to access without having to reach under the table plate or power stick to get to it.
We still have Aluminum plates and Phenolic plates for those that want a support surface that is really rigid in a 24x32 or 24x48 format for their new Buddys.
Hopefully this describes the differences between the first and second generation of the Buddy tools. Any further feedback, observations, comments that anyone would like to add are welcome either here or emailed to me.
