I am having a problem with my PRS standard drifting off on the Y axis while making finish cuts on a 45 degree diagonal. I finished rough cuts on some detailed carving and that worked fine but on the finish cut the Y axis drifts to the positive side at a rate of + or - .01 per pass. This drift is not at a constant rate. I have moved the wiring for the Y axis away from all other wiring and shut down everything but the computer and control box. This is a high priority project or I would wait until Monday for tech support at SB
Doug
