This week I did a clean install to win 2k, then tonight sb229.exe would not install, it will unpack to the winnt\temp directory and will create sb200 & sbpart directory it then gives a bad command or file name error when it try's to run inst2.exe
I tried running install from the command prompt to no avail, it also fails to create the sbdisk files.
Has anyone got a work around?
