Thread: Cutting 1/2 inch plexi
    Default Cutting 1/2 inch plexi
    I need to cut 2 inch letters in 1/2 inch thick plexiglass and the inside corners need to be sharp. What type bit and speed would I use for this?
    Feb 2004
    Sawdust and Noise, Brampton Ontario
    A laser, because you will always have radiused inside corners with a router bit (beveled corners and a V-carving bit excepted).
    Aug 2004
    Cromer, Sydney NSW
    Jerry,
    I use an Onsrud single flute spiral 3mm (1/8") diameter it has a 13 mm (9/16") Cutter edge length and if you use a climb cut it will gives a good cut quality. from memory it is either 56-012 or 62-012, could be wrong on the number. If you need I will be back at work after the 5/1/2009 so I can let you know then.
    The radius is almost negligible.
    David.
  1. Cutting 1-3/4 inch Oak
    By catbourger in forum ShopBotter Message Board
    Last Post: 04-24-2014, 07:37 PM
  2. cutting through 1 inch hardwood
    By dave_k in forum ShopBotter Message Board
    Last Post: 06-28-2011, 05:53 PM
  3. Cutting 1/16 inch grooves in acrylic
    By keith in forum Archive2008
    Last Post: 03-30-2008, 11:14 PM
  4. Cutting 1/4 inch MDF advice
    By bjones in forum Archives2006
    Last Post: 12-13-2006, 05:22 AM
  5. Cutting SIPS - a la 5 inch bit??
    By dubliner in forum Archives2006
    Last Post: 09-05-2006, 01:30 PM
