ShopBot suggests to rise the table sides by 6" (to add aditional table sides) to get the required clearnace for 12" indexer. But the down side is, that such type of modification creates more flex when cutting flat stock. Also, I think carving can be not as precise. Or maybe everything depends on the cut speed - if to set lower feed, cut speed, then maybe it should work fine? Has anybody did the table modification for 12" indexer according to ShopBot? Thank you.
