I am having a hard time changing the material thickness once created. At times I have had to reset the relief, delete it, or even delete the project and start over again because I could not reset the material thickness.
I am apparently not doing something correct because it should be a fairly easy process if you are wanting to repeat the the same cut file on a slightly different sized material.
