Results 1 to 10 of 18
Thread: Anyone know what these screws are called?
    Mar 2011
    West Chester, PA
    Default Anyone know what these screws are called?
    and where to find them?
    They seem uncommon, I need to match them on some work, and I can do an image search, but all I can find is Chinese sources at 30,000 pc minimums - and even though the picture is right, every place calls 'em something different.
    It is a bit frustrating that on the Chinese manufacturers' sites they are called "button head cap screws", "flat head cap screws" and about three other common names that are NOT these things.
    I need a few hundred in a black oxide finish in 1/4-20x1-1/2", and 5/16-18x1-1/2"
    I'd prefer a Torx drive, but an Allen head would work.
    Can anyone point me in the right direction?
    Brent
    Jul 2011
    Timmins, Ontario, Canada
    Ive seen them, but I looked at all my hardware suppliers and cant find anything...
    AJC
    Mcmaster.com : low-profile head socket head cap screws
    The head to shank ratio is less than what you show in the pic. You should contact some of the larger hardware distributors in the US and let them find them for you...then buy them from whoever finds them.
    Mar 2011
    West Chester, PA
    I looked at MCMC before I posted, - you're right, they are not the same.
    I will email some fastener people, but the low quantity that I need does not put me at the top of their customer service priority list.
    Jul 2006
    Hendersonville NC
    Brenton,
    There is a Fastenal in your area. If you haven't tried them, bring them a sample. If it isn't something they can help you with they are normally very good at pointing you in the right direction.
    http://www.fastenal.com/web/location...ester&state=PA
    Tim
    Sep 2008
    www.hafele.com/us page 421 furniture/cabinetry hardware book part# 264.88.350 sizes from 20mm to 40mm 1/4-20 black oxide
    Vector Studio 22
    they are called elevator bolts
    Funny how different parts of the country and different industries call the same thing by different names...
    Jerry... around here an elevator bolt has a flat flush head (no Allen recess) and a carriage bolt style protrusion under the head to keep it from turning.
    Brenton... I'm able to get bolts like what you are showing by calling them "connector bolts" they come male and female, with or without a stepped diameter on the male bolt to match the female diameter, various head diameters and finishes.
    Do you have a good industrial bolt supply locally that you can introduce yourself to? The web is a good source but a better source is a an old man who knows what different industries or even different manufacturers call something.
    Steve
    Mar 2011
    West Chester, PA
    Gene - these are really close, probably close enough. The ones I'm trying to match don't have the chamfer on the head, but I don't think it's a deal breaker.
    I like the name - very specific "joint connector bolt". Imagine how many returns you get in a search for that!
    Jerry - I thought they might be elevator bolts, but I looked up the definition in my Machinists Handbook, as well as images online and got this.
    "Commonly used in conveyor/elevator systems. For use in applications with rubber belting, these bolts are made with a large flattened Norway head, having a square shank under the bolt head before the threads. Elevator bolts have a flat head with no recess - must be secured from the back with a nut. Preferred where low profile required."
    I guess I'll call them connector bolts, non-specific and all-encompassing.
    Thanks all for your help!
    Brent
    garyc Guest
    Try Stafast: http://shop.stafast.com/catalog/17mm...oulder,156.htm
    They are Bill Young's GOTO hardware guys
  1. new drawing board design .real amazing called jumbo
    By woodman08 in forum Designing and Creating the sbp cutting file
    Last Post: 01-12-2016, 07:46 PM
  2. drawing board called super l vi usb input
    Last Post: 03-11-2014, 12:50 AM
  3. S0me one that called this weekend
    Last Post: 11-25-2013, 01:50 PM
  4. What's the colored plastic material called?
    By daniel in forum Sign Making
    Last Post: 06-11-2011, 02:29 PM
  5. How many layers of called files?
    By beacon14 in forum Archives2007
    Last Post: 01-09-2007, 12:54 AM
