Let's Talk ShopBot
Go Back   Let's Talk ShopBot > ShopBot Specific > ShopBot Buddy > Archives2008
Thread Tools Display Modes
  #1
Old 08-27-2008, 10:12 AM
Erik Francey erik_f is offline
Senior Member
Default Buddy Dust Collection
I have found the dust collection a bit of a pain to manage. I am working on something right now to try and get up and out of the way via the e-chain. Anyone else used the e-chain to manage their dust collection hose? Any great ideas out there?
  #2
Old 08-27-2008, 11:52 AM
Art Botterell acb is offline
Member
I tied up the hose section of the dust foot right behind the carriage... just used a couple of black tie-wraps in a chain attached at the upper end of the e-chain. Then I suspended the hose back to my d/c from a joist with a bit of chain.
Left enough slack in the chain to absorb the x-axis travel with a minimum of flexing the hose. And I can break into the d/c connection easily to run an extension hose to my less frequently used tools.
  #3
Old 08-27-2008, 12:38 PM
Senior Member
I was thinking of doing the same thing...but my garage has 10 foot ceilings...but I guess if I used your chain idea I could hang it as low as I like. My first set up worked fine until I finished my vacuum hold down...and now the plumbing from that gets hung up on the dust collection. If its not one thing its another!
  #4
Old 08-28-2008, 06:44 AM
Senior Member
ended up just hanging the hose over the rafter for now. Not really the ideal set up...but will work for now. Had just enough hose to get it done.
  #5
Old 08-29-2008, 06:30 AM
bearwoods@earthlink.net
Guest
Posts: n/a
Hi Erik
I am really a new Buddy 48 person as I still not up and runningyet. But I have ran into this type of problem before and will most likely do it with my Buddy. I run 4" PVC on the cieling to a spot directly above the machine then using dryer hose connect it to my Buddy. Dryer is cheap and lighter weight than my dust collect hose and a whole lot mort flexible. The plastic dryer hose has a wire in it for grounding. I run a thin braided wire through the PVC and connect then together and then to ground. Yes I have already set this up for my Buddy Although I'm not running yet. Good Luck.
  #6
Old 08-29-2008, 09:27 AM
bradywatson's Avatar
Brady Watson bradywatson is offline
Senior Member
Here's what I've done...Machine is FILTHY from very large run of parts. I've been using the Buddy as a secondary operation tool, where parts get grooved, drilled and other operations, allowing me to keep my setup on my big tool. It's a beautiful thing having multiple robots making you money at the same time! Even though I have a good DC setup, I don't always use it, as certain setups with clamps or low cycle times, make the DC foot self-defeating...or it simply gets in the way.
Here's my setup consisting of a Rigid brand vacuum hose, a 2 to 3" adapter for the foot, a 2 to 4" adapter for the DC to plug into. For a small tool such as the BT series, a 2" hose is more than adequate & it is self-managing, as it bends with the same contour as the energy chain.
The setup allows the Buddy to be completely portable, and is ideal for anybody with high or low ceilings, a powerstick and/or vacuum system like I made on my BT.
Old 08-29-2008, 11:46 AM
Senior Member
Nice work as usual sir. I was thinking along the same lines but just making the 4" DC run the whole way back. My workable shop area is pretty small, so keeping this in order keeps swearing to a minimum. I will try and take some pics when I get it squared away.
  #8
Old 08-29-2008, 12:52 PM
Senior Member
Thanks Erik.
Not all ideas work out, but you usually learn something in the process...Here's an articulated arm that I made. It worked well as far as the arcticulation went...but a bit too bulky & complicated for dust collection. PVC elbows sandwich HDPE bearings with a sort of labyrinth seal to keep the air pressure, but allow for movement.
  #9
Old 08-29-2008, 03:02 PM
dana_swift's Avatar
dana swift dana_swift is offline
Senior Member
Brady, my hat is off to you for experimentation!
Rube Goldberg would have been proud! But if it works that is the test of the "pudding".
D
  #10
Old 08-29-2008, 11:38 PM
Member
Here's my chain-up arrangement. (The square item down front is a wifi antenna.)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 1999 - 2010 ShopBot® Tools, Inc.
