This is a new one to me:
Parameter Error
Parameter value above range for VS set to upper limit (12)!
Now, what does that mean in English?
Parameter Error
You tried to enter a speed value beyond the limit. Depends on the axis. Mouse cursor over the field will tell you the limit of the axis.
I haven't changed any of the settings and it has been running for the last few days.
All the numbers are at default....no where near the limit.
I've tried changing the numbers and still get the same message.
"Sheet"
36108.gif happen... have you worked it out yet?
Well....it seems that the problem was a loose nut in the keyboard. Frank from ShopBot told me that my feed speeds were too high, but that didn't seem possible because it was the same that I had always been using.
As it turned out, it seems that somehow the speed value in the software had gone from inch/min to inch/sec...which is guite a difference. I set it back to inch/min and everything is peachy-keen again.
Computers are such a joy.
