Let's Talk ShopBot
Go Back   Let's Talk ShopBot > Applications and Techniques > Designing and Creating the sbp cutting file > VCarvePro and PhotoVCarve
Reply
Thread Tools Display Modes
  #1
Old 11-02-2006, 03:15 PM
myxpykalix's Avatar
jack jarvis myxpykalix is offline
Senior Member
Default Lithopane questions for Vcarve pro and photoVcarve?
I have d/l the demo but haven't opened it yet. Here is my question. I want to make a lithopane using a picture and also an element downloaded from the vectric forum. In the photovcarve video tutorials it doesn't show combining elements so that i could combine these 2 elements to make a lithopane. I would attach it here but its 2 megs its called "Frame002.zip" located at: http://vectric.com/forum/viewtopic.php?t=444
about 1/3 down from top of page. and this picture (attached)
Can anyone look at this and tell me if it could be done? Thanks
  #2
Old 11-02-2006, 03:42 PM
Joe Nagel joenagel is offline
New Member
Jack,
Yes you can combine the two files. What you need to do is set up your photo and tool paths in Photo vcarve. Then instead of saving the .sbp files you simply do a file/save as and save it as a .pvc.
Then open the frame file in Vcarve pro and import the .pvc file of your photo. All of the tool paths from Photo vcarve will be included in the import and show up in the toolpath list.
You will need to delete the .75em roughout and .125 center finish toolpaths in vcarve pro as those two are created to cut out the center of the frame and I'm assuming that is where you would like to put your litho.
Joe
  #3
Old 11-02-2006, 04:31 PM
Tony McKenzie tony_mac is offline
Senior Member
Hi Jack,
There's a Tutorial (Video and a PDF Manual) avaialble from the Vectric web site that explains how to import PhotoVCarve files into VCarve Pro.
It's the 4th tutorial down the page > VCarve Pro Tutorials
As Joe said, it's very easy to combine the toolpaths for a lithophane inside a vcarved design.
There's also a very useful video tutorial explaining how to limit the toolpaths in PhotoVCarve inside a specific region such as the oval shape of your design.
Removing background detail from pictures
I hope this helps and let us know if you have any questions or need assistance.
Tony
  #4
Old 11-02-2006, 08:00 PM
myxpykalix's Avatar
Senior Member
I downloaded the trial loaded up the pic per instructions. It basically only gave me options to see a preview of the pic carved in wood and what i saw didn't look good and i'm sure due to the peramiters i selected. I used the "invert colors" check box because i thought i remembered from a tutorial that was what to do for a lithopane. I tried it also withoput the invert.
Here is what i got. I left all settings alone when loading picture, using 60 degree v bit for cutting, material thickness is .25 depth of cut was .15. This looks almost as if it is just a roughing pass preview? I thought i followed the tutorial, the program seems pretty intuitive. I also tried the preview using the tool 1/8th" ballnose and preview didn't look much better.
  #5
Old 11-02-2006, 08:07 PM
myxpykalix's Avatar
Senior Member
Is there any way someone who owns V carve or photoV could take that picture and make it into a file 8X9 that i could load up and cut? This would allow me to see what this program could do for me for lithopanes. Is that too presumptious to ask for that? The preview I made put the watermark in it and i'd rather not waste a piece of corian if it is going to cut that watermark into the picture. This looks like it might be a pretty neat package. If anyone could do that for me i'd appreciate it much. Thank you
  #6
Old 11-02-2006, 08:35 PM
Terry Doherty terryd is offline
Senior Member
Location: Signs of the Times in Brighton, Brighton Ontario
I only charge $180 per hour. Thats what I got the bot for Jack, making money. The only way I could make money was to take the time required and learn the software. It takes time and if your willing to make that investment, as seriously as you made the cash investment for the equipment then you will realize the great potential of the machine you have. Apologies for sounding curt but I do think your last request was very presumptious and is pushing the "brotherhood of the forum" a little.
TerryD
  #7
Old 11-02-2006, 08:38 PM
Pascal Riendeau (Paco) paco is offline
Senior Member
If you want to see some nice examples, visit the VETRIC forum.
As for testing the softwares, I believe you have some trial files to machine.
  #8
Old 11-02-2006, 08:56 PM
myxpykalix's Avatar
Senior Member
Terry,
I guess my perception of help and yours is different. If this is as easy a program to use then creating a file shouldn't take someone a few minutes to do. If that is asking too much, then please disregard my request. On the other hand when asked in this forum for info that i could contribute on spirals and indexers i went and took pictures wrote detailed explainations that took 10-15 min to research and post and thought nothing of using the programs and info i had to do that to help someone else. Isn't that what this IS all about? If I was going to use this file to make money then i would see your point.If its about money, then anyone who could make me this one file please email me with a price to do that. Thank you
  #9
Old 11-02-2006, 11:08 PM
Scott Cox scottcox is offline
Senior Member
Jack,
I tried Photo V-carve and wasn't really pleased with the outcome. I think it states on the website that the details are much better on 'large' carvings. My 4"x5" trial just wasn't able to capture the details in the drawing.
Anyway... I've decided to talk to some local artists about converting my photos to line drawings, so I could v-carve them. One understood the v-carving concept right away and her work should carve nicely, but the other just didn't get it and instead tried to convince me that his way (thin-lined, not really v-carve material) was best.
Pick your poison. ;-)
  #10
Old 11-02-2006, 11:43 PM
myxpykalix's Avatar
Senior Member
Well the vcarvings i've seen (signs) looked great made with this, I haven't seen a carved picture up close (hence the request) but the lithopanes look great that have been made with this.
There is a free app that will convert your photo's into drawings. Ask brady, i bet he knows what it is.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
