Let's Talk ShopBot
Go Back   Let's Talk ShopBot > ShopBot Specific > Variations & Modifications of ShopBots > Archives > Archives2008
Thread Tools Display Modes
  #1
Old 03-30-2008, 03:26 PM
Ed Stutz bearcat is offline
Junior Member
Default The QUAD
I have been working with Luthiers Mercantile Int., www.lmii.com, to setup and move current and new product production onto their new PRS Alpha. It came time to build a vacuum holdown system and using Brady's open source vacuum project thread as a starting point, I designed and built this system, nicknamed the QUAD.
The 5' x 8' table is split into 6 equal zones, each with a 1" grid 3/8" deep into the table and a matching grid 1/8" deep into the 3/4" Trupan spoilboard. Each zone has a vacuum gauge.
ABS drainage plumbing is used throughout to take avantage of its smooth flow design. The table zone manifold is 3" ABS and is mounted under the front rail with Al straps and guillotine style u-bolts from McMaster-Carr. Specific zone plumbing is 2" ABS with 2" gate valves with stainless steel paddles. The valves are from www.westpacsupply.com
Four VBTST13431AEAD motors are mounted to a 15mm plywood housing containing a 3" ABS plenum. Each motor is on it's own power switch and 15amp breaker. 1 1/2" ABS and gate valves are used to switch intakes/exhausts for 2 parallel, 4 parallel, or 2+2 series parallel operation.The 4 mufflers are also from Lighthouse Ent.
For maintenance, all valves were bonded with silicone rubber and the right side of motor housing is a bolt-on.
With all table zone valves closed, the vacuum is 10+in Hg for 2 or 4 motors in parallel and 17+in Hg 2+2 series parallel. The series motors do heat up quickly with no airflow, so I use this only for very short runs with some leakage.
The system has run now for about 3 weeks with no problems. It is loud, even with mufflers. Larger parts are easily held with 2 motors. With smaller parts or many cuts, I've switched on the 2 other motors during the run to maintain vacuum.
Installed left view
Installed right view
Left side of motor housing
Front of motor housing
Motor plenum
Motor mount
Zones manifold
Manifold strap
Zone Valves
Gate Valve
  #2
Old 03-30-2008, 03:50 PM
Sheldon Dingwall dingwall is offline
Senior Member
Nice work. It has the look of real craftsmanship.
  #3
Old 03-30-2008, 04:07 PM
chiloquinruss's Avatar
Russ Wood chiloquinruss is offline
Senior Member
It just needs some Nascar stickers on it cause it looks really 'fast'!
Wonderful workmanship, I can tell you have real pride in your shop and your tools. Well done. Russ
  #4
Old 03-30-2008, 05:42 PM
bradywatson's Avatar
Brady Watson bradywatson is offline
Senior Member
Beautiful work, Ed! I love it!
I'm not big on stickers...but some polished diamond plate or airbrushed flames would be pretty slick! I sure does look 'real fast'
Old 03-30-2008, 08:09 PM
Pascal Riendeau (Paco) paco is offline
Senior Member
Very nice work! Make me wonder why I have been all around for schedule 40 white PVC...!
  #6
Old 03-30-2008, 08:17 PM
Rob Bell rob_bell is offline
Member
That's pretty cool, Ed. I like it. It looks to me like it's supposed to be loud.
  #7
Old 03-30-2008, 09:33 PM
joe crumley joe is offline
Senior Member
Very Impressive,
What do you think it costs?
What type of work do you usually do that will require such a heavy system?
  #8
Old 03-30-2008, 09:36 PM
Senior Member
Very Impressive,
  #9
Old 03-30-2008, 10:33 PM
myxpykalix's Avatar
jack jarvis myxpykalix is offline
Senior Member
"Transformers...robots in disguise"
  #10
Old 03-30-2008, 11:17 PM
Stephan Voelkel steve4460 is offline
Senior Member
Nice work . Just make shure you have an extiguisher near by , so this dosen't happen http://www.talkshopbot.com/forum/mes...tml?1206932107
Bot on
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 1999 - 2010 ShopBot® Tools, Inc.
