Let's Talk ShopBot
Go Back   Let's Talk ShopBot > Applications and Techniques > Techniques for Cutting, Drilling, Machining > Archives > Archives2007
Thread Tools Display Modes
  #1
Old 12-14-2007, 07:30 PM
David Petrie davidp is offline
Senior Member
Default Feed Rates for cutting PVC
Hi all,
I have a job coming up cutting 135mm dia (5 1/2") circles from 15mm (5/8") PVC. The part also has 5mm holes drilled approx 12mm in from outer edge and an inner profile as well.
My question is what chipload should I be looking at to achieve a smooth cut.
What strategies have others used cutting PVC. Any assistance or advice on do's and dont's would be appreciated.
Regards,
David.
  #2
Old 12-14-2007, 07:45 PM
bradywatson's Avatar
Brady Watson bradywatson is offline
Senior Member
David,
What kind of PVC? Sintra/Komatex etc expanded foam PVC or rigid gray PVC?
Old 12-15-2007, 02:16 AM
Senior Member
Brady,
It is rigid gray PVC.
Any Hints tips infor would be appreciated.
Regards,
David
  #4
Old 12-15-2007, 12:21 PM
islaww's Avatar
Gary Campbell islaww is offline
Senior Member
David...
I have done some cutting in the rigid gray pvc as our table and plenum is made from it. SHARP endmills are OK but not as good as O Flutes. Keep bit as short as possible to avoid chatter if making agressive cuts. Get the RPM as low as possible to avoid heat. When we did the spoil board I used a 3/8 2 fl BN @ 1.5 ips around 8500 rpm. 1st pass @ .25 deep and 2nd @ .318. We used a 1/4 sgl O flute for the perimeter gasket and it cut much better.
Try toolpathing at 1 ips and 10K rpm. Then bring rpm down until bit scream goes away. Then bump up speed till you get nice curls off the bit. Keep the DC hoses clear!!
Gary
  #5
Old 12-15-2007, 05:32 PM
Senior Member
Gary,
Thank you. I suspected that my RPM was too high around 14,000. I used a 1/4 single O flute at around 70 mm per second (approx 2.6 ips) a 8mm per pass.
I will slow everthing down and I will post the results.
Regards,
David
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 1999 - 2010 ShopBot® Tools, Inc.
