Let's Talk ShopBot
Go Back   Let's Talk ShopBot > ShopBot Specific > ShopBot Accessories > Archives > Archives2006
Thread Tools Display Modes
  #1
Old 06-12-2006, 03:23 PM
Phil O'Rourke phil_o is offline
Senior Member
Default Dust skirt design
I'm looking for a dust skirt design that I can easily build at home. They look fairly simple but I'm sure there are some creative designs out there.
  #2
Old 06-12-2006, 04:18 PM
Roger Kirkpatrick thewoodcrafter is offline
Senior Member
I'm looking for some good ideas also. I have 2 Z's I would like to pipe into 1- 4" duct.
Has anyone gone to the trouble to design a dust skirt that would lower with the router and raise with it but stop raising (to leave room under it for material change) to change bits. It would stop raising to give room to change the bit. Mounted on some sort of slides with adjustable stops in both directions with springs or something.
  #3
Old 06-12-2006, 11:54 PM
Mike John mikejohn is offline
Senior Member
I just searched for 'dust skirt' and found 59 threads.
I can not point you to any particular one, as many seem to cover the topic you area asking about.
If you search, I think you will find what you are loking for.
If not, come back and ask for more details.
Also try www.mechmate.com and go to the Forum.
Lots of good Shopbot modification stuff there.
.............Mike
  #4
Old 06-13-2006, 02:20 AM
Senior Member
Gerald, I had one similar to this when I had 1 Z.
Seemed to work O.K. The brushes are the trick.
But with a second Z I don't have enough room for the hose to run down next to a router.
So I planned on splitting the hose, running it outside the car and pull dust from each end, behind the routers.
I guess I will make a double holed skirt with 2 dust ports that lead outside, around the car.( if you get the picture) So I don't think I will have much room to change bits with the skirt down.
I hope to rig up something that will retract from the bits as the routers raise, so I can get to the bits. But maybe, as I am writing this, I could have a removable side instead of a removable end, like yours. I will have to get to the side anyway to change the bit. The hoses will be in the way on both ends.
Now for the trick, where do I get those brushes?
  #5
Old 06-13-2006, 03:28 AM
Gerald_D gerald_d is offline
Senior Member
...down the road from USABCO in my case, but my road is 8000 miles from yours.
Here is an old thread for you:
http://www.talkshopbot.com/forum/messages/27/1101.html
  #6
Old 06-13-2006, 06:28 AM
Jeff Hamilton handh is offline
Senior Member
Does anyone have a dust skirt for the drill unit. Looks like Shopbot would have designed one for this as well.
  #7
Old 06-21-2006, 07:50 PM
Senior Member
I made a dust skirt using a stock shop-vac angled nozzle. My thinking is that the angled nozzle will aim the suction toward the source and collect chips more efficiently. It works well. The skirt is plastic recycled from a gallon milk jug. I'd like something a little thicker.
  #8
Old 06-27-2006, 10:49 PM
Mike Healy imacarver is offline
Junior Member
Phil,
Very interesting design. I am assuming this fits around a router and not a spindle? Does Shopbot supply a dust skirt?
  #9
Old 07-01-2006, 08:00 PM
Senior Member
The design is for a router. Shopbot does have a dust skirt available.
  #10
Old 07-02-2006, 04:09 PM
David Hunt. dhunt is offline
Senior Member
Yes, SB does have a very nice CLEAR dust skirt available:
my friend just received one with his new PRT-96.
This SB-supplied dust skirt also included about 2.5 ft. of 4 in. clear flexi-hose,
the first bit of it squished to an oval-kinda cross section for the first 1 ft. or so,
then it's regular circular hose.
And at the connecting end(to your vac.system) there's a handy alligator clip stuck on to the last exposed 6 ins. of the metal 'cord' built into this clear spiral tubing,
this functioning as a static electricity discharge feature!
All in all, a very nice device, this much improved SB-made dust skirt!
I checked SB webpages to see if it's available separately,
but the only mention of it is that it comes supplied with a PRT machine, when you buy a machine.
SB could be selling these things like hot cakes as a cool after market accessory, to each and every present SB owner, but what is the cost??
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 1999 - 2010 ShopBot® Tools, Inc.
