Let's Talk ShopBot
Go Back   Let's Talk ShopBot > Applications and Techniques > Sign Making
Reply
Thread Tools Display Modes
  #1
Old 12-26-2009, 01:19 PM
Raymond Chapman joewino is offline
Senior Member
Default Lithophane Christmas
I'll post this in the sign section since that is what I do for a living.
This is a lithophane I did of our grandchildren as a Christmas present for my wife, Jeanne.
Overall size is 9" x 14". Face is 3/16" acrylic.
It was designed with ArtCam Pro and produced on my ShopBot PRTalpha.
  #2
Old 12-26-2009, 04:16 PM
Phil O'Rourke phil_o is offline
Senior Member
Very nice Ray. Good looking kids too.
  #3
Old 12-26-2009, 09:53 PM
islaww's Avatar
Gary Campbell islaww is offline
Senior Member
Raymond...
Nice! I think there is some woodworker in there along with the signmaker.
Gary
  #4
Old 12-27-2009, 10:56 AM
Senior Member
Looks like you come up with a light source that works very well.
  #5
Old 12-28-2009, 09:03 AM
Senior Member
Phil - the light is a 13" florescent unit normally used for under counter kitchens(from Home Depot). I replaced the rocker switch with a lamp cord that has a switch in-line.
It gives a softer light without having a bright spot, plus it doesn't build up as much heat. There are some holes in the back to allow for ventilation.
  #6
Old 12-28-2009, 09:13 AM
Donald G Clifton donclifton is offline
Member
Have you thought of using white LED's. This could be mounted between the face and clock movement and produce 0 heat.
Don Clifton
  #7
Old 12-28-2009, 09:19 AM
navigator7's Avatar
Chuck Gallup navigator7 is offline
Senior Member
Raymond, is the lithopane three pictures (Of the stunningly attractive kids) combined into one or is this one photograph?
From the time you pushed start....how long did the carving process take?
  #8
Old 12-28-2009, 12:11 PM
Senior Member
Chuck - I took three photographs and combined them into one using Photoshop. While there I cropped them down and adjusted the contrast, and converted them to gray scale.
And I agree, they are very attractive kids...but then I'm prejudice. The young lady is our first grandchild and just turned 18 yesterday. The boys are both 13.
LED's would probably work well too, but I was on a limited budget and having to use what I could find around the studio and locally. The light was actually bought with a Gift Card that I had received earlier.
The process took about 90 minutes.
  #9
Old 12-28-2009, 05:14 PM
myxpykalix's Avatar
jack jarvis myxpykalix is offline
Senior Member
hey Raymond you should do a search for and use "cold cathode lights". They emit almost no perceptible heat, are rated to run continuously for 30,000 hours and are cheap. A pair of 12" lights are around $8.00 and a wall wart plugin less then $10.00.
They give you a nice even glow across the whole length without any hotspots and you never have to worry about any heat buildup.
Cold cathode lights are the same kind of lights the grocery stores use in their refrigerated boxes like where the milk is displayed, next time you are at the store check them out only the ones you buy are WAY smaller. Here is one link for future reference:
http://www.xoxide.com/dual-white-cold-cathode-kit.html
  #10
Old 12-28-2009, 05:22 PM
Jerry Stanek jerry_stanek is offline
Senior Member
Jack what if your litho is a standard 8 X 10 picture? The nice thing about led lights are they are cheap last up to 100,000 hrs no heat and you can run them off a 12 volt battery if power is not available.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 1999 - 2010 ShopBot® Tools, Inc.
