Let's Talk ShopBot
Go Back   Let's Talk ShopBot > Applications and Techniques > Sign Making > Archives > Archives2005
Thread Tools Display Modes
  #1
Old 06-02-2005, 05:53 PM
Ryan Patterson ryan_patterson is offline
Senior Member
Default Signabond
I have a customer who brought me this product signabond http://www.signamag.com/signabond.html I was hoping for some help on what cutter I should use and at what speed. I have a prt alpha with PC router.
  #2
Old 06-02-2005, 09:54 PM
Jay Pollard jay is offline
Senior Member
Location: ThingsWood, 105 Keystone Court, Thunder Bay Ontario, P7C 2E6
Sure sounds like Dibond or Alucobond. This link may help you. The material cuts like butter with my PRT. Alucobond manual
  #3
Old 06-02-2005, 10:54 PM
Senior Member
Jay,
Yes it seems to be the same. I have to cut a name and a logo thourgh it. I think I will need to use a 1/8" bit to get the detail he wants. The total thinkness of the signabond is about 3/16". What type of bit would you use and at what speed would cut at. I looked at the Alucobond manual and does to say to much on routing other than for bending using a 90 V-bit. Does the aluminum peel up when cutting.
  #4
Old 06-03-2005, 04:12 AM
Sign chap (Unregistered Guest)
Guest
Posts: n/a
Cut this stuff all the time. I use a standard two flute spiral at 3.95mm
Feed rates are around 1700mm p/m for me. Find it cuts really well. I set the pierce rate for the Z axis quite low at around 200mm.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright © 1999 - 2010 ShopBot® Tools, Inc.
