Let's Talk ShopBot
Go Back   Let's Talk ShopBot > ShopBotter Message Boards > ShopBotter Message Board > Archives > Archives thru 2002
Closed Thread
Thread Tools Display Modes
  #1
Old 03-11-2002, 07:31 AM
paulmagras@caribsurf.com
Guest
Posts: n/a
Default Router bits
can anyone tell what company make the best quality router bits to be used CNC machines i am thinking of making gingerbread for buildings so i need bits that will stand up to 8-12 hours continuous use [ using a shopbot]
  #2
Old 03-13-2002, 04:55 AM
Gerald_D gerald_d is offline
Senior Member
For the Americas, Onsrud is probably a good starting point for a search.
  #3
Old 04-17-2002, 01:05 AM
tom@allexsign.com
Guest
Posts: n/a
ok, the Onsrud are quite excellent bits, but please take a look at the BELIN spiral "o", they have a mirror polish and are about $22.50 ea. Solid carbide, upcut, yes upcut that leaves a glass edge in most materials. We started using them in august of 2000 and thats all we have gone with ever since. they are razor sharp, quiet, and cut like a dream. the longest I have used one of these bits at one time was approx. 10.5 hours. Depending on the material you are cutting, you will get thousands of inches before you will need to buy a new one. I dont have the direct phone number, but go to multicam.com to get the dealer closet to you. By the way, we have used the onsruds and compare very well to the spiral "o", but because of the polish on the spiral "o", ejection is better. Also, one last piece of info, the belin spiral "o" is made overseas, in france, if they were manufactured here in the us, they would have a price tag of about $80.00, thats how well they are made. Just passing through for updated and saw this article, thought this would help.
Thank You,
Tom Byron
Unit Production Manager,
ABC Pet Products Intl. Consumer Products Division.
  #4
Old 04-17-2002, 02:14 AM
Senior Member
Hi Tom, We use Belin because France is nearer to us (and I go there sometimes). I only suggested Onsrud as a starting point because they seemed bigger in the US.
By the way, France being a metric country, the Belin metric sizes are less expensive than the inch sizes.
  #5
Old 04-24-2002, 06:35 PM
edrawe
Guest
Posts: n/a
I am just now recieving my shopbot can someone tell me which bits I should get first. I plan on making house signs and also will need to cut out parts for various projects.
Thanks in advance
  #6
Old 04-24-2002, 08:33 PM
Senior Member
Just a very rough idea:
60 degree V-cutter
1/2" straight (square-nose) cutter
1" straight (square-nose) cutter for surfacing table and other odd jobs
1/4" straight cutter if it will fit your router
  #7
Old 05-11-2002, 08:18 AM
jrw00d2@aol.com
Guest
Posts: n/a
I am carving photographs on my Bot and I am looking for a sign/engraving bit but with a very sharp angle, the only ones I have been able to find so far are 60 deg that taper to 0. any ideas?
  #8
Old 05-11-2002, 12:49 PM
Jeff Guinn
Guest
Posts: n/a
Jay,
Eagle America ( 1-800-872-2511/ http://www.eagle-america.com/ ) sells a 45 degree bit , part # 132-1022.
  #9
Old 05-11-2002, 08:06 PM
david@thecarpentershelper.com
Guest
Posts: n/a
Jay,
Try multicam.com they not only sell software and machines they have some really good 1/4 inch bottom feed engraving bits down to .030 with a very steep angle they are called bottom feed because in ingraving machines you either load bits from the top of your machine or the bottom. David in Wyoming
  #10
Old 05-13-2002, 09:02 AM
Doug Roughton doug is offline
New Member
Hey Paul M./Gerald D./Tom B:
Heard an interesting bit of info at the Jamboree, the manufacturers of the Belin bit are the parent company of Onsurud. I too have used and am very pleased with the quality and performance of the Belin bits. However, I purchased some Onsrud bits at the Jamboree, can't wait to give them a try.
Just thot' you would like to "hear what I heard".
Doug in Oklahoma
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
