Let's Talk ShopBot
Go Back   Let's Talk ShopBot > General > Virtual Show and Tell > Folder 17
Thread Tools Display Modes
  #51
Old 01-26-2010, 04:46 PM
magic's Avatar
magic magic is offline
Senior Member
This mich works great
http://www.harborfreight.com/cpi/cta...emnumber=66319
  #52
Old 03-19-2010, 06:34 AM
Greg Banet gregb is offline
New Member
I'd like to thank Chris for starting this thread and sharing the prototype file. This was a fun project. Its being installed in a door for a peep hole (that was a cool idea). And, I'd like to share these files with all.
I redrew the iris making some small changes and after three attempts I finally finished the project. I used 1/4" Masonite (actually measures a little shy like 3/16") and 0.09" aluminum and used a 1/8" end mill for all the cuts. 1/4" x 3/8" shoulder bolts hold the large gear. The holes for the small gears were drilled, 1/8" and fitted with a short lengths of 5/32" brass as bushings which accepted 3mm screws for good fits. 3/16" holes were profiled with the 1/8" endmill on the large gear and the leaves where the arms attach and fitted with #6-32 tee nuts which protruded slightly through the Masonite. On the underside of the aluminum arms, I countersunk the holes just enough to fit snugly over the tee nuts and #6 -32 x 3/8" screws secured them. I attached a piece of clear acrylic to cover the hole. I used thread lock on all screws.
No matter what fasteners you use, as long as there is no slop, this should turn freely. This was a problem in my first two attempts. The large gear would move left or right instead of turning.
These might not have been the best choices of materials but, it worked fine. I think the next one I build will be entirely out of aluminum.
Hope you enjoy.
Click image for larger version
ID:	9233   Click image for larger version
  #53
Old 03-19-2010, 09:17 AM
jdervin's Avatar
John Ervin jdervin is offline
Senior Member
One of the things I like about the wood/masonite versions is that the iris completely closes. I doubt that it's possible to completely eliminate the center hole with overlapping metal leaves (though it can certainly get quite small).
For what it's worth, here is a different version of a professionally manufactured iris -- this one is intended for use in a stage lighting instrument.
Name:	Iris Closed.jpg
ID:	9237 Click image for larger version
ID:	9238 Click image for larger version
  #54
Old 03-20-2010, 06:48 PM
shoeshine's Avatar
Chris Schaie shoeshine is offline
Senior Member
NICE... Greg,
This project got "back burnered" due to a backlog of other work, but it has been itching at me the whole time.
I will definately incorporate the outside gear. Thanks for posting your files. I -have- to get at least one final piece made for the upcoming camp/s over here on the west coast.
I hear ya on the wood/masonite. I actually was thinking that the working parts on my final will be milled out of brass.
anyway yippee! I love seeing how others run with an Idea.
Thanks again for posting.
__________________
Do not follow where the path may lead. Go instead where there is no path and leave a trail.
  #55
Old 03-20-2010, 07:10 PM
T.G. Marino tgm is offline
Member
Greg,
Did you actually use the files posted to cut the parts for the unit shown assembled?? Thanks for posting by the way, but there seems to be a problem with the size of the large gear component as the diameter appears to be too small. The radial slots seem to have a smaller bolt circle diameter than the shoulder bolt holes in the base.
Can you check before I resize and screw something up??
Thanks again,
Tom in PA
  #56
Old 03-20-2010, 10:11 PM
New Member
Chris, I hope you get caught up with your other projects and give this a try again. I'm anxious to see some pics.
Tom, here is another file with the parts separated, nothing nested. All the holes mainly show location and I initially drilled all of them with a 1/8" end mill. I had changed the diameter of some of the holes when I changed the fasteners diameter and just drilled these out by hand. Don't change position of anything; maybe re-size depending on the fasteners you choose. Hope this explains what you need. If I can help with anything else, let me know.
  #57
Old 03-20-2010, 10:44 PM
Member
Thanks Greg, I'll give it a whirl!
Tom in PA
  #58
Old 03-21-2010, 11:39 AM
zeykr's Avatar
Ken Zey zeykr is offline
Senior Member
Looks like fun. Thanks for the files.
__________________
Ken Zey
Rogers, AR
www.CedarSlabSigns.com
www.lookoutmercantile.com
6x12 PRS alpha
  #59
Old 03-29-2010, 02:41 PM
mikeacg's Avatar
Michael P. Schnorr mikeacg is offline
Senior Member
Default Something to keep the brains thinking...
As long as we are playing with mechanical designs, I remembered seeing this and being fascinated. I'm sure some of you have already seen this but it might be worth posting for those who haven't:
http://www.wimp.com/expandingtable/
http://www.dbfletcher.com/
__________________
Mike Schnorr
www.artcentergraphics.com
www.baconwood.com
  #60
Old 03-29-2010, 09:25 PM
chiloquinruss's Avatar
Russ Wood chiloquinruss is online now
Senior Member
Reminds me of the 'rhythm' clocks.
http://www.allabouttime.net/MivaImages/BNEW.jpg
Russ
Tags
gears, iris
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
