Let's Talk ShopBot
Go Back   Let's Talk ShopBot > ShopBotter Message Boards > ShopBotter Message Board
Reply
Thread Tools Display Modes
  #1
Old 01-20-2009, 09:55 AM
Gerald Martin gerald_martin is offline
Senior Member
Default Spray Room Exhaust Fan
Hello All:
I have a small (8'x24') spray finish room in my new shop building. There is a filtered air inlet from the main (workshop) part of the building.
I'm looking for a small exhaust fan to vent fumes to the outside. Would prefer if it could fit between two studs on 24" centers, and have a louvered vent.
Any ideas or suggestions? Definitely want something safe as I spray lacquer occasionally. This is for occasional use, not continuous commercial.
Gerald Martin
  #2
Old 01-20-2009, 12:59 PM
Fred Phifer Call-Tech is offline
Senior Member
Grainger sells them, however they might be cheaper if you can find it elsewhere. They have smaller ones in 12", 18" etc.
Here is a link to 24" Grainger exhaust fan with shutter. Has fully enclosed motor which protects against explosions if you spray flammable products.
http://www.grainger.com/Grainger/items/1HLB2
  #3
Old 01-20-2009, 01:09 PM
RB99 rb99 is offline
Senior Member
If the fumes are flammable, then you have to watch out for fans that blow the exhaust over the running motor. Automotive spray booth fans have the motor encased on the outside of the fan housing and spin the fan with a belt that is also enclosed.
It should also have non ferrous blades so if they get bent and scrape the side they don't cause sparks...
P99
  #4
Old 01-20-2009, 01:20 PM
wberminio's Avatar
Erminio Marrese wberminio is offline
Senior Member
If you spray flammable be sure to get an Explosion Proof Motor!!!
DO not take chances.
Any spark can create an explosion from the spray fumes,even if only used occasionally.
It only takes on time.
Erminio
  #5
Old 01-20-2009, 01:21 PM
dakers's Avatar
dick akers dakers is offline
Senior Member
you can copy and paste this into your browser.
in ebay looked for paint exhaust fan.
you can put a motor on this if you can get it at reasonable price. check craigslist also.
i always look for bargains because i do not have enough money for everything. but i do have a $4,000 bicycle so maybe i do not want to spend alot on exhaust. We bought a spray booth at auction fro $4,500. then had to put in fire suppression. had to run the tube out 6 ft from building for fire code. I could have got another good bicycle with all that money.
http://cgi.ebay.com/Dayton-Tubeaxial...arms=72%3A1205|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1| 294%3A50#ebayphotohosting
  #6
Old 01-20-2009, 02:13 PM
james mcgrew cabnet636 is offline
Senior Member
after looking at the cfm range and price of the grainger, tools usa is a bit more expensive and this is a good bit more than i paid for some of these just 18 months ago,
http://www.toolsusa.com/asp/item_detail.asp?T1=PBE+9MS+LSD1633XVA20&GENB=& amp;UID=
  #7
Old 01-20-2009, 04:14 PM
Senior Member
Thanks for the input, everyone...
Grainger's fan looks alright but it is not rated as explosion proof, even though the motor is sealed...
http://www.industrialfansdirect.com/LFI-AX18-4.html
will I need to spend $700 to get something functional and safe?
Anyone?
Gerald
  #8
Old 01-20-2009, 05:18 PM
bcammack's Avatar
Brett C. Cammack bcammack is offline
Senior Member
Or you could put the room under positive pressure so the air is forced out through the filters.
If the fan is across the room and not near where you are spraying, whether or not it is explosion-proof isn't very relevant. If a motor is brushless and has no contactors, there isn't going to be much of an opportunity for a spark to occur.
  #9
Old 01-20-2009, 06:38 PM
Senior Member
It is my understanding that a totally sealed motor is sufficient for use in spray booth. If the contents of spray booth is that explosive then gasketed and sealed fluorescent lights become a larger concern than the motor in the exhaust fan.
-Fred
  #10
Old 01-20-2009, 06:43 PM
Gregory Cochran glcochran is offline
New Member
look at ebay, and search "Multifan" there is a 20inch currently for sale. I'm using the 18" version and it works well, sealed motor, plastic blades, fiberglass shroud, lots of air movement, and rather quite. You can also get a speed controller. Grainger has specs and sells unit for more than 2x.s the buy it now price
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
