simple questions about adhesive/sealer
I've spent hours reading everything I can on plenum/vac/tables. With all your experience, what is the best adhesive to use between my birch and the plenum and what is the best sealer and application method for the plenum? (yellow glue, poly, shellac, tight bond, etc.) Should I surface the birch plywood before attaching the plenum? And wouldn't it be more adaptable to use gasket in the cut lines instead of leaving a 1.5 inch ridge between your zones? Then you could change your zones as needed.
