Looking for a hint...DXF Import.
Hello all.
I have ordered a buddy and am cramming prior to its arrival.
I use Sketchup Pro to create multi part structural assemblies in 3d.
I have done so for years and like having that tool on my belt as it's use is 2nd nature to me now.
Normal procedure for me it to "blow" the completed assembly apart into its components, lay all of the components flat on plane, and finally refine components.
Then I print measured prints and take them into the workshop to sweat over.
Now, with the Buddy coming, I really want to export individual, component specific 2d DXF files to Partworks.
I have used all of the advice found here and am able to produce DXF that are clean after import to Partworks. I Feel good about the workflow...and glad that it appears that i can keep using Sketchup to desing as i am used to.
So here is the problem. My vectors are not the same size in Partworks as they were in Sketchup. Sometimes larger, sometimes smaller (maybe an inch or so over a ten inch part. Should be 10" and is 11.something after import.
Not a consistent variance.
I have searched this forum and have not seen a discussion of the problem
(so it must be me I suppose...no surprise there...i dont mind being the new guy no matter how old I get. It makes me feel young again).
I use inch decimal in Sketchup...and that is what I see in partworks.
So...any hint as to how to get dimensional correct exports to Partworks from Sketchup? I always assume operator error before anything else...and am hoping it is something I am doing wrong.
Thought*...maybe i should try PDF or some other export/import avenue?
In any event...thanks for reading. I will be here often.
Mike P
