Move & Jog not working properly, Move is too fast and jog is too slow!
I'm working with an older PRS Alpha 96x48 (with the USB to serial adapter) and today after turning it on it's moving faster when moving than jogging, and jogging appears to only move 30% the distance I command it, while moving moves something like 130%!
If I MX 12, it moves about 16". MX 6 moves about 8". Same for MY.
http://www.talkshopbot.com/forum/ima...or/menupop.gif
JX 12 or JY 12 results in very slow movement and about 3-4" of movement.
Move and jog speeds are set to defaults (12.00 for jog and 3.00 for move), slowing it down doesn't seem to change anything for Move at least (it moves slower, but still goes the 16" instead of 12), I didn't measure Jog after changing speeds.
All moves result in showing the entered distances (so it thinks it's at 12 after MX 12, even though it's really at 16). It will lose zero if I mix jogs and moves.
I've reset the settings using the default PRSAlpha settings, and it made no change.
I saw a similar thread here and followed everything in there, multiple restarts, unplugged (power) shopbot controller and reloaded firmware.
Settings from VU:
[CODE]
X Unit Value 2482.8171
Y Unit Value 2482.8171
Z Unit Value 2979.3805
A Unit Value 2979.3805
B Unit Value 13.8889
Circle Resolution .05
Small Circle Def (OBS) .25
X resolution Mutiple 5
Y resolution Mutiple 5
Z resolution Mutiple 5
A resolution Mutiple 5
B resolution Mutiple 1
Step interval driver 1
[/CODE]
