Help Please!
I have a 1 in black pvc board it is bigger than my table and have to split it in to 2 pieces. The sign is 10'x2'. I have a 1/4" bit specifically for hard plastic and have a v-bit (60 degree). I was wounderg if someone can help me tuning infeeds and speeds for both.
This is what i have come by Please correct me if im wrong.
for the 1/4" i have an onsrud 63-727
Pass Depth - .25 in
Step Over - .1 (50%)
Spindle speed - 1300 rpm
Feed Rate - 2 ips
Plunge Rate 1 ips
for the 1" cutting diameter 60 degree V-Bit
Pass Depth - .25 in
Spindle speed - 1600 rpm
Feed Rate - 100 ips
Plunge Rate 30 ips
Please help and thank you for your help.
You don't need a special bit for black PVC because it's a soft plastic. A table saw would be your best bet but since you have extra material, why not run a test on the material edge. I'm always amazed how generous this material is with different bits. I've found a test on speed rate is required. Not all black PVC cuts the same so it's necessary to run a test or two.
I trust this isn't to be used outside! It's famous for warping and turning ugly dark gray. None of the manufacturers warranty it for exterior use.
right pvc is easy. I choose a bit for diameter and keeping the parts in place. so for larger parts a upcut is fine if not a straight works well. but with a 1/4" 1/2" pass is fine.
I cut 1/2 inch PVC all the time with a 1/4" bit in one pass. It really does cut great.
5 Attachment(s)
I am a model maker and use a lot of black/white 1/8th and 1/4 inch pvc. The same rules apply with pvc as when cutting wood, make CHIPS not dust. If you feed to slow it will MELT in the cut, a little faster and it cuts like butter. It holds great detail if the bits are SHARP and CLEAN. Hold down is important as well because it will flex while cutting, and I also use a lot of tabs which can be cut with a utility knife. A good vacuum table works the best. The pix shows some detail done using a 1/16th tapered ballnose, door on left is 1 1/2 inch by 2 inch, door on right is 3/4 inch by 2 inch. Fun stuff, glues with regular old pvc pipe glue. Russ
http://www.talkshopbot.com/forum/att...id=27391&stc=1
http://www.talkshopbot.com/forum/att...id=27392&stc=1
http://www.talkshopbot.com/forum/att...id=27393&stc=1
http://www.talkshopbot.com/forum/att...id=27395&stc=1
