4 Attachment(s)
CNC tooling - new and used - for sale
I have a large quantity of CNC router bits. Asking $850 for the whole lot.
Located in beautiful Asheville, North Carolina. I have a strong preference for cash money and selling in person.
Here is the list:
NEW router bits
Whiteside solid carbide
RU2075CN cove nose up cut spiral 1/4 diameter, 1/16 radius quantity 2
UD2102 up/down cut spiral 2+2 compression 1/4 diameter
RD1600 down cut spiral 1/8 diameter quantity 3
RU1600 up cut spiral 1/8 diameter
SC062 straight cut 1/16 diameter
Onsrud solid carbide
65-025 Upcut Spiral O Flute 1/4 diameter
72-005 5mm shelf-pin boring bit 10mm shank
77-102 3 flute, ballnose, taper 1/8 diameter tip
63-774 Upcut Spiral O Flute 1/4 diameter
63-760 Upcut Spiral O-Flute 1/8 diameter
Onsrud Sign bit
37-92 Double Flute Carbide Tipped Lettering Router Bit 120 Deg V 2" Diameter 1/2 shank
Amana Tool solid carbide
51415-K Spektra Coated Spiral 'O' Flute 1/16 diameter
51410-K Spiral O Single Flute Plastic Cutting Up-Cut 1/8" diameter
Amana Tool carbide tipped
45422 straight cut 1/2 diameter
Amazon/Chinese solid carbide bits
HRC55-2F spiral taper
Box of 8 1/8 spiral ball nose
CNC *USED* bits in good condition
45912 Core Box 1/4 Radius x 1/2 Diameter
45733 60-degree V bit 3 flute 9/16 diameter
46380 Up-Cut Ball Nose Spiral 1/4 Radius x 1/2 Diameter
46190 compression spiral 1/2 diameter
46341 down-cut spiral 1/8 diameter
51410-K Spektra Coated SC Spiral O Single Flute 1/8 diameter
60-123MW compression spiral 3/8 diameter
63-781 1 Flute Upcut O Flute 3/8 diameter
48-008 straight cut 2 flute 1/8 diameter
63-794 Single Flute - SC Upcut Spiral O Flute 1/4 diameter
52-910 Two Flute Up-cut spiral 1/4 diameter
63-760 Upcut Spiral O 1-flute 1/8 diameter
56-240 straight cut 2 flute 1/8 diameter
63-751 Upcut Spiral O Flute 1-flute 1/16 diameter
Onsrud carbide tipped
48-005 One Flute Straight V Flute 1/4 diameter
SC12 quantity 2
Amana replaceable-insert bits
RC-1076 engraving body + new RCK-420 cutter + RCK-360 cutter in good condition
RC-1045 45-degree V bit
RC-1108 60-degree V bit
RC-1072 72-degree V bit (missing cutter and screw)
RC-1102 90-degree V + new replacement cutter RCK-134
RC-2250 Mini Surfacing & Rabbeting Flycutter 1.5 diameter (2 of 4 cutter surfaces unused)
Attachment 35100
Attachment 35101
Attachment 35102
Attachment 35103
