Originally Posted by
MechanoMan
Yet one should not throw up one's hands and declare it incomprehensible because the problem has variables and variable standards.
Clearly there's a wide variation in the achieved vacuums people have worked with. It'd be good to know what people found a useful minimum. Are we saying 9"Hg as a minimum to get "basic" results?
Hmm, how does this work exactly? See a bleeder board might lose 80% of its thickness before being replaced. When "new", a high vacuum underneath doesn't mean high holding force on top. If you fail to resurface the sealed faces of the bleeder board, you develop high vacuum but no CFM.
Conversely, if you had a perforated (drilled-through) conventional vac table, but only used a fan with low vacuum, you could see some high figures for CFM, but this wouldn't equate to holding force.
I'd think "vacuum at the workpiece" would be the appropriate figure, however, there is no appreciable pressure drop at the open surface for a Trupan bleeder board. Or a perforated board, either.
I think what we're looking for is a SEALED surface pressure drop. That is, you have a cup with a rubber seal on the rim, and stick it on the table. How much pressure drop is there in the cup? That should dictate holding force. If you have a low-porosity bleeder board that you failed to surface, you would develop "impressive" vacuum underneath but the lack of vacuum on top would be apparent. Similarly, if you had a perforated bleeder board and didn't cover the unused holes, you get impressively high CFM but again the surface cup test shows the low vacuum pressure indicating poor performance.
The cup would need to be large enough that the sideways leakage- CFM- under the seal does not relieve the generated vacuum. That sort of leakage is going to happen even if the seal were "perfect" and the cup was glued to the board, because the bleeder board is porous by nature.
Yes of course cuts in the surface from prior use will mean you have greater pumping requirements until resurfacing. I do see that. But the test would lead to a proper understanding of the design requirements.
For example, I'd like to be able to know that "for a standard 1/2" Trupan board, properly faced, you need X inches of static underneath, which loads down the pump with Y CFM per sq ft. This will allow you to cut a 1 ft diameter circle of plywood with a 1/4" bit of a certain type at a certain depth-of-cut and IPM".
From there a person could say "I have an impressive 5HP spindle and want to cut faster" or "but I need to cut smaller parts at the same speed" and be able to calculate what the vac pump requirements are to achieve a solid hold under different side forces.
Just, not this guesswork thing. So far I've seen anecdotal accounts going all over the place.
