It's here! (And running too.)
Well, I went over to the freight terminal and picked up the crate this morning. It was quite impressive to watch the forklift operator put the crate in my truck as there was less than an inch of clearance on either side!
I got the thing home and started to uncrate it. It was too heavy to lift off the truck so I loosened the clips at the bottom and removed the whole top and sides at the same time. I then cleared the old machine out of way and moved the new one in. (By myself... Ouch.) I had previewed the setup information so it took less than an hour before I had to wonder in and grab the laptop. Everything worked out of the box and by 2:00 I was cutting a lithophane into a 5x7 piece of Corian.
At that point, ever willing to turn a good situation sour, or a bad situation worse, I decided that I should go ahead and hook up the dust collector. And promptly hit the power switch I reached around it...
Everything was working well up to that point though. And the dust collector is hooked up now too.
So, next on the list: I need to pick up some bits. I got the "starter set" from Shopbot and I've got a good number of 1/8" v-bits and such. I think a visit to MLCS and / or Centurion is in order. The question is, what should I get? I'm going to be making lithophanes, small signage, and such. What do you guys and gals keep in stock?
What do you use to carve in blue foam? I've routed sheets of bricks for stage sets before and seem to recall that I just used a standard bit. It's been awhile though.
OK, off to prep for a Marine Corps League meeting and grab a bite.
Cheers!
