I will if I ever get done, brother.
I'll send you the files if you like. They'd be a nightmare to figure out, but if you made your own toolpaths it'd be pretty easy. Or not. :)
Edit:
I just looked at the zebra.
Ya know how the bit chucked a few of the real soft, short pieces, Scott? I can usually get them to stay by sneaking up on them. Rather than getting down to the flat depth in one or two passes, I'll go down in two mildly aggressive passes, then do the last pass real thin, like a tenth or less.
You'll have to play with that process to see what works best for the size of your model and the softness of your wood. You can actually test on just part of the zebra, the really short bits. That way you can run a number of tests in a real short period of time.
Remember what I mentioned about the patience part? Yeah, it's a real challenge. :D
You're still going to lose some short bits because of grain voids. In those cases, wood filler is your friend. I xacto out the glue and lay it in. Then I stain the inlay with something light so it hides the putty. That way I'm the only one who can see it. :)
