Hey Mike,
Just to make sure we're all on the same page, this is a regular PRT gantry tool and not one of the PRT Benchtop units? And nothing has been modified... just a new computer and software install?
Hey Mike,
I'd also wonder what type of limit switches do you have? Are they the black plastic ones or the barrel style? For a PRT it would likely be the black plastic switches - we would then want to see if they are functional. They'll have a red LED that should trigger when a conductive piece of metal is passed over the switch sensor.
Finally we would check where the switch wires, normally they will have a 3 wire cable with a ground (green), +5v wire (red), and an input wire (black). Ground goes to GND/Ground, red to +5 and the input normally would go to input 3 for both.
where do yours wire and do they operate normally? that will help determine what the VN settings should be
-Tom
Also what voltage are they? There are both 5 volt and 12 volt switches out there. On my board there are two blocks of screw down connectors. One of them has a 5 volt output at its end position the other has a 12 volt output. It turned out that my limit switches needed to be connected to the 12 volt output to work.
One problem I have found with my machine is that over time Shopbot has changed how things are wired up and the printing on the mainboard was never changed. I (for instance) did not realize that they no longer use the solder in position on the board for the current setting resistors on the Gecko drives. Instead they just put the resistor in the connector block of the drive. This caused me to really heat up one of my motors because the absence of a resistor in this position makes the drive go to full output.
This is the tail end of the benchtops, that shortly after became the buddy line (apparently with little change from what I have)
The limit switches are the magnetic sort and test appropriately with a magnet (light goes out when a magnet is near)
the part that really has me scratching my head is that it worked before I updated windows and reinstalled the control software.
I just tried a second laptop to see if that might be an issue but found exactly the same things going on (limit switches tripped, x and y reversed)
I am wondering if there might be another version of the software I should be using, but so far I have not been able to find it.
As to the wiring, one of my limit switches is wired to input 2 and the other to input 3. I can try them both on 3 and see what happens for sure!
I don't mean to be "that guy" by asking this, but are you sure that you're selecting the correct settings file when you install the software? I have one of those PRT Benchtop and the setup is different than the gantry tools?
I'm happy to say that all is now well. I had tried all the tips and suggestions here and also been on the phone with tech support twice. I called tech support again last night with some new thoughts and I was up and running in about 3 minutes. The irony is that we didn't do anything that I hadn't already tried many times before. Oh well, all is now well!
Thank you all for your help in working through this!
The suspense is killing us! What ended up solving the problem?
The resolution was swapping the settings for input 2 and 3 for the limit switches and inverting the value for the y axis. The frustrating part was that we tried those limit switch choices many times before and it didn’t work. In the meantime I’ve updated my computer to a newer model that meets shopbot’s Recommended capabilities to remove future problems
