If you are running a PRS - it is impossible to overtighten them. On a PRT the correct tension is 3.5 turns on the buckle just as the spring starts to get some tension on it.
Also, flatness of your spoilboard is paramount. It will haunt you forever and mess up jobs etc if it is not glued down to the plywood support board - with zero screws in the lamination. It should be machined flat with a large diameter bit so that table is true to the tool. This will remedy the 'cutting deeper here and shallow over there' condition. - Provided that the parts are being held down correctly.
Flatness is very important. A few cutter kerf tracks here & there isn't.
