4 Attachment(s)
Sometimes..Simple is best
Customer liked that last Stella design so much they opened an account, BUT wanted one that looked more like a Compass Rose.
Did one right off the bat based on the Stella design, BUT thought it was too similar and spent several days on/off getting "Fancy"and VCarving and bitmap tracing:(
In the end they liked the simplest/fastest cutting one the best:)
Easy to overthink things for me:)
Also a close up that looks like an optical delusion(or I'm tired)....And YES, The countersink for buttonholes should have been ON the line...I know,I know,.....:)
4 Attachment(s)
Torrefication levels compared
Had to resurface and seal my torrefied button backer/spoilboards with General Finish "Woodturners Finish" (water based PU with 1 hour recoat for THICK layer),so during one of the waits I dug out my Torrefied samples from closet.
Just thought I'd post for anybody interested.
Now that I see them again, I remember that until you get to about C-80, it machines like regular wood for the most part, except it cuts clean and more like dust than chips above C-50(at least for surfacing).
Would have been more interested if Dad had got some Soft Maple(and I see some people are offering Cherry? :)
http://www.torrefactionplus.ca/torre...od.php#qualite
Would be worried about screwing or bolting without careful testing. Did joint some pieces of C-90 Ash and glued with TB I, II,III, and Gorilla PU for a strength test as I had read gluing was horrendous, but Max G. got around to to gluing the exact wood Dad had given him with TBII and said it was a normal TB joint and wood failed before glue line so mine are still glued together after 18 months and still good after being knocked/dropped around the shop.
Put a straight edge on those surfaced sample boards that were surfaced 18 months ago, and even though they were just leaning against a closet wall, and humidity is 30% higher now..They're all still perfectly flat.
Last pic the color is lousy, but they are both C-90 Ash and the one on the left is my backer board with 4 coats of woodturners finish and right is just rough 4/4 that we have so much of.
Interesting stuff and think I might like the C-50 through C-70 in a closer grained wood than the Ash I have.
Interesting article about Martin Guitars
http://onemanz.com/guitar/articles-2/torrefication/
and was nice to finally see a pic of the vac chamber.
http://mectorrefaction.com/index.html
