Cutting marine ply gingerbread
For the third time in as many years, my 15hp vacuum system bought from ShopBot has jammed. I have not yet pulled it down to fix it, but from past experience, there will be a small(very small) chip of aluminum from one of the turbine blades(?) caught between a blade tip and the walls of the case as has happened previously. Has anyone else had this problem and if so, how did you cure it?
All intake filters are in place and clean, piping to the vacuum table is not leaking and mdf spoil board in good shape.
Many thanks.
