I finally received my ShopBot and in the process of assembling it, but I have a few questions hopefully someone could answer.
1. The diagram in the manual shows the x-1 motor located on the rear side of the unit farthest away from the control box. However the x-1 motor cable is shorter than the X-2 cable which is closer to the control box. Is this correct or are the cables probably mislabeled?
2. The manual shows all the control cables going through the hole in the center of the gantry beam. But it doesn't actually say if the power cable for the router should be fed through there as well. I would think it shouldn't, so as not to create electrical interference. But if doesn't feed through there, how have people been routing the power cable after it leaves the e-chain over to the control box.
3. The e-chain I received seems to be short as I can not mount it as per distance and location as specified in the manual and still get full travel of the motor mount across the the y-axis. Anyone know what the actually length of this e-chain should be.
4. I have a package of black plastic rectangles approximately 2"x4" in size with plastic prongs on the back. I can't find any reference in the manual to what these are and what they are for.
5. There was no wiring diagram of the control box, though I thought this was usually included, or is not anymore.
