I'm sure that it's something simple but I can't figure it out. I cannot get the router to start! The software is engaged, I can move the tool, run a file - everything but get the router to run. I was cutting some parts just fine but needed to stop the process in order to re-size a couple of holes. Pressed the space bar and stopped it as it should. I reset the control box, reloaded the file, reset the Z axis zero - everything fine until I pressed the start button on the box - no router start-up. Shut everything down, started from the beginning and everything worked as it should except the start button. I can hear it click inside the box, but the router won't start. I plugged the router into another outlet and it works, so the problem isn't the router, but I can't figure this one out. Any Ideas?
