I have been running a Delta 1.5 HP dust collector and I get by with it. It is mounted on a cart and I keep it hooked up to my SB and my manual router table it is Y'd to both the SB CNC and manual router table each hose has a plastic blast gate at the DC end. When I run my cabinet saw I switch the one hose over to my cabinet saw.
I cut plastic almost exclusively the chips the routers make are easily picked up but the saws makes this stringy stuff that is like steel wool and plugs the duct so I have finally given up using it and just clean the cabinet saw out by hand and use a shop vacuum on the chop saw. The plastic really does not make much dust at least that can be seen.
My system is pretty basic but the cart is in the way and the hoses lying on the floor are a pain. I am going to build a small room on the end of the shop and I would like to add a new DC system in there and also move my 7.5 HP air compressor out to gain more room in the shop and reduce shop noise. I plan to have a double door outside to access both machines I would also like to put in a small door to allow emptying the chip bin from inside. The plastic likes to get statically charged and fly around when emptying the system and I don't want that mess outside it is easier to vacuum up the mess if it is on the concrete floor inside the shop. I plan to put a bathroom vent fan in the room with vents in the bottom to keep the room cool for the machines. I will insulate the walls to help keep the noise from escaping outside.
I have a 20 amp 220 service already in that corner I could use to power the DC and the air compressor service will reach the location also. I am just starting the search but I am thinking I would like a cyclone type collector. I have been looking at the Grizzley tool models and I am thinking the 2 or 3 HP models does anyone on here use one of those models? Can you turn me on to some other brands as well?
I am thinking I would like to duct the unit onto the ceiling and then have drops for my cabinet saw, SB CNC, Manual router table, chop saw, panel saw & band saw.
Thanks Mike
