Has anyone tried to mill their own branding iron from solid metal? If you have seen the electric heated branding irons. In particular for branding wood.
Branding irons are either cast or forged. If you care to heat steel to melting point and pour it in a mold you can certainly use a cnc router for carving a master to create a sand mold from.
Red,
If you can get the resolution that you need, you can mill your own branding iron/logo in brass. It would be very similar to the ones that Rockler sells.
-Brady
I believe the electric branding irons for wood are machined from brass. You should be able to get good results on a bot with the correct cutting bit and lube.
Thanks for the replies. The design I had in mind is rather "simple", so I thought the bot would be able to handle it.
Any ideas on how "thick" the brass would need to be?
Red, how big is the pattern/logo? The thickness will vary according to the size of the "iron".
I've milled branding irons out of brass with no problems on my router. Fine details in small letters are limited by the size of the bit you use. I really don't remember feeds/speeds at this point, it has been awhile and I didn't take notes as I probably should have.
You can see a sample at www.cncworks.biz, click on engraving and it is the first image. Worked out OK, except I was having some problems with perfect repeatability in Z, so the background has some variance.
My problems came in maintaining appropriate pressure and temperature to make it work consistently. I think the attachment for the drill press would probably be the be the easiest to control.
Donn
By, the way, the size is about 1.5" X 2.5" or so.
Donn
Donn,
I checked out your site, nice work. Is the gold and brass paint on the corian lids One Shot or something else?
Mike
Donn:
How were you heating it?
Gerald:
In the range of 8 to 12 sq inches.
