Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Half Blind Dovetails
  1. #21
    West Des Moines, Iowa
    Mike...
    Because both joint elements (pins and tails) contain both "inside" and "outside" arcs, we'd produce a shape mismatch between tails and pins. If each element contained only "inside" or only "outside" arcs, then your shortcut could be used to good advantage.
    There are two other (completely independent) considerations that contribute to making joinery on the ShopBot "interesting":
    The first is step resolution - there is no way to, for example, accurately split 0.001" (or even 0.005") on the 'Bot.
    The second comes into play because each tail, and each pin, is located with a single reference point and all other points in that tail or pin are computed from that reference point and each point is computed relative to the preceeding point. This, in combination with the fact that the ShopBot control program uses a low-precision floating point format, requires that, to avoid unacceptable cumulative errors, I perform those computations outside the ShopBot environment using a higher precision floating point format.
    I discovered this when I observed a difference between geometrically identical toolpaths produced by PartWizard and those computed (using sine, cosine, and tangent functions) within an SBP program.
    All of this together means that the "glue gap" value needs to be examined and either applied to just one of the joint elements - or (perhaps unevenly) split and applied to both tails and pins.
    And no one is likely to specify a gap as large as 0.01" unless they plan to grout/spackle the joint.
    In any case, it's a "solve once and forget" kind of problem - it just introduces a bit of complexity to the development that I hadn't anticipated.
    ...Morris
  2. #22
    Just to provide a bit of closure, I've completed construction of the 3-1/2 axis joinery machine. Along the way, I posted pictures of each stage of construction on my JBot web page.
    All three axes have a step size of 1/4800" (0.00023") in a 12x12x4 workspace to address the "glue gap" problem.
    I've been busy learning g-code.
    Morris
  3. #23
    Jul 2005
    Des Moines, Iowa
    Morris,
    Good to see that this is coming together. Do you have any pictures of your first test cuts with the machine?
    Looks great.
    Dave
  4. #24
    Oct 2006
    , San Diego California
    Why not use the Dovetail bits, and avoid the round corner problem????
  5. #25
    Mark...
    Sorry for the slow response.
    I wanted more options - and I wanted a stronger joint than dovetail bits allow and control of the "tightness" of the joint.
    Not to hijack the thread - but I'll mention in passing that I built a (possibly interesting to some) fixture that allows me to cut angled tenons with my bot. There are a few photos on this web page.
    ...Morris
    ...Morris
  1. Blind Dadoes
    By ssflyer in forum Cabinetry and eCabinet/ShopBot Link
    Last Post: 04-15-2014, 07:11 PM
  2. blind dados
    By 2006prt in forum Cabinetry and eCabinet/ShopBot Link
    Last Post: 05-31-2012, 09:38 PM
  3. Blind Dadoes
    By bill_lumley in forum Cabinetry and eCabinet/ShopBot Link
    Last Post: 02-21-2010, 10:05 PM
  4. Half table for 3 axis, half for 5 axis?
    By nodnerb in forum Table
    Last Post: 10-05-2007, 09:57 AM
  5. Carve half now - other half tomorrow
    By applik in forum Archives2007
    Last Post: 01-22-2007, 09:42 PM
