Still won't fly.
Can you copy and post the ini file for me? V carve still thinks it's a post processor.
The air must be really thick down here. lol
Still won't fly.
Kenneth
I managed to find a config settings type of folder elsewhere and coppied the info into it.
I still have these two error messages, even when using Gary's post.
Giving up for tonight.
Kenneth
Here is what my post processor file area looks like and the info in the ini file.
Kenneth
Kenneth,
I think I see something that may be the problem or a problem after fixing the first problem.
I looks like you may have the .ini file named with a double extension (.ini.ini).
If you go to your postp folder, you'll see (as in your attached image) that your postp's don't show a file type extension in there name, but it looks like the "ShopBot_run.ini" file does have one. If you go up to "Tools/Folder Options" and click on the "View" tab, look for "Hide extensions for known file types" and remove the check mark from it. Hit "Apply/OK" and you should see that your "ShopBot_run.ini" has an extra .ini. Rename that to have only one .ini and you should be good to go.
Thanks Scott.
That did it. I need to play with what numbers I have in there, but at least it's opening.
Kenneth
Great, goes to show ya that two ini's don't make an outi.
