Every file I make with Partworks resets the file limit checking to on. And then I get the annoying popup window everytime I run a file that says I am beyond the table limits. I know I can go in and manually put in a line that will turn it off, but that is annoying to do with every part file I create. Is there a way to tell Partworks to put in the line automatically or to not reset the limit checking? I'm using Partworks 3.0 and I have a PRT4896 alpha with a retrofitted ATC installed.
Tim
