I was running a file this evening for my son- peck drilling a few hundred 1/2" holes for breather holes in a new brooder box. All of a sudden the machine stopped moving. it was frozen in place moving from on hole to the next. I let it run for a few minutes - trying to let it clear its memory and go on. No such luck. Now when I try to run it using an FG command it does not allow me to run it.
I get two errors: One indicates that the "command is not supported" and the other is "run time error 9"
I am going to go do some research on these- but if you guys can tell me what might be my issue, it would be very much appreciated. I will also send Frank an email with a couple of pictures. This will probably all make sense to him right away...
Thanks in advance.
