I have been experimenting with different bits cutting .177 and .22 clear and black acrylics. Trying to get a cut that will not require edge prep before gluing. So far I have not been happy. I will list the bits I have used and a 1 - 10 rating on the edge finish. 10 being the best. Does anyone have any other suggestion in my quest for a perfect 10? I have tried many different speed/feed with these bits and have not had much of a difference in edge quality. I am using vacume hold down, pressure foot and just to make sure my stock is not moving at all spray adhesive.
Harvey Tool
Plastic Single "O" Flute Up Cut 1/8" # 51508 my rating 6
Plastic Single "O" Flute Up Cut 3/16" # 51212 my rating 5
Plastic End Mill Up Cut Spiral 2 Flute 3/16" # 48712 my rating 3
Plastic End Mill Strait 2 Flute 3/16" # 14612 my rating 7 (best bit overall, so far)
Amana Tool
Plastic Single "O" Flute Up Cut 1/8" # 51410 my rating 6
Plastic Single "O" Flute Up Cut 3/16" # 51412 my rating 6
Onsrud
Acrylic Single "O" Flute Up Cut 1/8" # 63515 my rating 6
Acrylic Single "O" Flute Up Cut 3/16" # 63520 my rating 5
If you have another bit recommendation please list model # and the speed/feed you are using to get the best edge finish.
2nd problem
I am also using a Amana Tool In-Groove CNC Insert Engraving Tool with 90° V-Tip Engraving Insert Knife / 0.04" tip width. Does anyone have any tips for speed/feed to get a clean cut .02" deep engraving in acrylic without the white tool marks.
Thanks for the help.
Brendan
