Results 1 to 10 of 17
Thread: Gears and a clock
    Feb 2004
    Cabinetpartspro,Inc., Naples Florida
    Default Gears and a clock
    I had some time this weekend to make a clock. I started off by thinking I would go with a pendulum and weight but I wanted to be done in a day, I did not want to waste the time playing with the timing of a swinging pendulum. So I bought an AC synchronous gear motor and figured the gear ratio from the motor. The motor spins at 6 RPM. The math from the motor is 6:1 for seconds then 60:1 for minutes and 12:1 for hours. Total gear ration it 4,320:1 .
    Jul 2010
    Morrilton Arkansas
    Ryan,
    Did you use your gear program to do this?
    Feb 2004
    I used a Vectric gadget I created. You can get it here http://www.vectric.com/forum/viewtopic.php?f=27&t=13908. The Gadget will also work in PartWorks.
    Looks great!
    I guess backlash isn't a concern because it only rotates one way.
    Jan 2008
    OK you got me! I'll have to try some acrylic! Very cool, thanks for posting. Russ
    Apr 2011
    Cincinnati
    Ryan where did you source the synchron motor from? Do you have any issues with it running hot?
    Mar 2009
    Pope Valley CA
    That looks great Ryan!
    It even comes with a guarantee!!
    I've been wanting to make a clock for too long, now. I just need to get going on it! Thanks for the inspiration.
    Ron Sloan
    Feb 2004
    Jun 2012
    Philadelphia
    Quote Originally Posted by ryan_patterson View Post
    i downloaded this gadget do i need to install it somewhere or will it just run from where ever?
    "The most valuable tool I have is the experience of others" - Me
    Jun 2012
    Philadelphia
    nevermind figured it out but i need to create a ring gear i don't think this gadget will do that any sugestions?
  1. Square Gears, Non-circular Gears and Kinetic Sculpture
    By Bob Eustace in forum ShopBotter Message Board
    Last Post: 04-02-2014, 08:15 PM
  2. Fun with gears...
    By scottbot in forum Folder 2012
    Last Post: 07-14-2012, 09:31 PM
  3. Fun With Gears
    By tuck in forum Folder 2011
    Last Post: 11-10-2011, 01:30 AM
  4. gears
    By mitch_prest in forum ShopBotter Message Board
    Last Post: 11-18-2010, 10:55 AM
  5. Gears / CAD
    By jb218 in forum Archives2004
    Last Post: 01-12-2004, 03:57 PM
