Hello,
I am trying to troubleshoot a problem that I am having with my shopbot. I have the model equivalent to the Buddy, although it is the older version of the model. The problem I am having stemmed from when activating the spindle through the ShopBot Editor, the spindle was not turning on. I tried resetting the GFCI and it seemed to work for a little awhile, then the problem returned. I thought that the GFCI might be bad, so I replaced it and the shotbot worked fine for awhile and then the problem returned. I am wondering is any of you could give me insight on some things that I can try to get my machine back in consistent operation. I am wondering if the control box has an issue in the power being sent to the spindle. Thanks in advance for your help!
