Results 1 to 6 of 6
Thread: Source for Longer Bits
    May 2012
    Columbia, MO
    Default Source for Longer Bits
    Many of my project require that I cut to (or through) 8/4 or thicker hardwood along very specific profiles as part of the cut.
    Through much "experimentation," I've learned to generally do this reliably, but it is still quite the challenge on some pieces. Preventing heat issues while still allowing for chip clearance and yet avoiding chatter...it is a good thing I like puzzles.
    Not helping me, however, are the bits themselves. I understand that the CEL is a function, in part, of the strength of the carbide. I rarely cut more than 0.25" on a pass anyway. But the overall length (OAL) length of the bit is something I fight regularly.
    I can find 1/4" CED/1/4" shank spiral downcut bits with an OAL of 3", but I can't for the life of me find an upcut bit of that length. The best so far: 2.5". But that leaves me almost no room to hold the bit in the collet properly and still clear the surrounding materials. As you all well know, collets don't cut wood very well .
    Ideally, I'd find 3.5" length bits. That would be heaven.
    Any good sources of longer bits out there? All suggestions welcome.
    (Also, since I'm posting, has anyone ever tried a 3 or 4 flute spiral bit on wood?)
    May 2008
    Port Orange Florida
    Try cutting tool source they will make you any bit you want. http://www.cuttingtoolsource.com/
    Don Clifton
    John,
    I use a 1/2" 3-flute down spiral on parts I make for a local plaque company cutting 8/4 alder into shapes. It cuts VERY well and I am very pleased with the results. The only problem is I can't remember where I got them...
    Dec 2009
    WiLL PACK, LLC, Franconia NH
    John - try Vortex tool http://www.vortextool.com/index.cfm?...category_id=13
    They also have 1/4 upcut ballnose - with 4 OAL....as well as making any custom bit you need - too. Yes - I typically use a 3/8 chipbreaker 3-flute for plywood profiling and for roughing passes in 3d carving work.
    Tom
    Micro 100 has 4 inch bits
    Yup...and check either OBergBrothers.net or any metalworking tooling reseller or end mill manufacturer. You can get Super Extra Long end mills, which are the same identical grind that 'stupid woodworkers' over pay for when they are renamed 'upcut spiral router bits'.
    If you haven't already, be sure to check out Micro100, Harvey Tool, SGS and OSG. Lots of good stuff there...and all kinds of 'secret squirrel' bits for those wise enough to need them & find them Quality tooling makes a HUGE difference if you use your machine professionally.
    Also, consider using tooling diameters that are uncommon...that is to say, a 'sneaky Pete' 3/16 or 5/16 size tool can make all the difference in the world for a number of reasons...like stiffness, cutting length and reach, with little effect on kerf width and internal radii.
  1. Source for speciality bits
    By Stephen50 in forum ShopBotter Message Board
    Last Post: 05-11-2013, 08:56 PM
  2. Source for V-carving bits
    By joewino in forum Archives2006
    Last Post: 10-11-2006, 10:52 PM
  3. Source for 1/8" ball nose bits??
    By myxpykalix in forum Archives2006
    Last Post: 10-10-2006, 08:57 AM
  4. Source 4 router bits
    By gene in forum Archives2006
    Last Post: 09-21-2006, 10:55 AM
  5. Router Bits Source
    By pjldesigns@hotmail.com in forum Archives2006
    Last Post: 01-24-2006, 07:32 AM
