Hi All
One of the most fundamental points of CNC machines is that the axes are straight. But, with good measuring tools (eg. autocollimator), we will see curvature, bumps, twists, dips, etc. in any rail. All of us have probably fiddled with at least our long x-rails and have gotten to the point where we decided, "this is straight enough".
Now that we have a very stiff gantry, we can see that our x-rails are not as straight as we had thought - at some spots, one flank of a v-roller loses contact with the rail. (I can slip a 0.002" feeler gauge in). A more flexible gantry simply bends to accommodate that small imperfection, and maybe the stiff gantry will cause the high spots to wear off....?
Has anyone got some ideas on getting really straight rails? Let's keep it to our SB-styled "sharpened" plate/angle edges, and not get into linear bearings. (Unless we look at the beds for linear bearings, which also have to be straight - the bearing just bends to fit the bed).
For, our gantry lengths, we can use a local guy that has a "bed way grinder" on which he repairs lathes and other machine tools, but our wide table won't fit on his grinder to do the x-rails. I am trying to think of a way of re-grinding the x-rails after they are bolted/welded down......
