I guess this is as good a place to "fess" up to my clumsy removal of the cover on the V1000 VFD. I was removing the cover and was having trouble with the last hex head bolt on the cover....getting it aligned so it would turn easily and release from the case and......wham!, it came loose and the cover dropped to the floor thereby pulling the rj 46 cable out of board on the inside of the VFD. The "block" where the rj 46 plugs in was slightly pulled away from the rest of the innards inside the box but seemed to snap back into place ok. When this happened I thought that if there were problems at "fire up" time, this would definitely be the probably source. So yes, the led display on the cover didn't light up. So I put a new rj46 cable on which didn't fix it and also checked the voltage between "sc" and "s1" just to make sure there was power (as per Yaskawa tech support suggestion) and all appeared ok. So now it looks like I need a new cover since the terminal connection where the rj 46 plugs in to the back of the cover appears loose and also the block inside the VFD where the rj 46 plugs in on that end....at a minumum....ShopBot tech support doesn't seem too awfully responsive and I want to move forward with the fix. Might it be best to just deal with a third party parts and repair outfit? I was so close to having this machine up and going! I'm so bumned out that I was so clumsy!
Randy
Randy
