Steve, Packet ET after the MX move was good(only use single axis 4" Moves so that apples remain apples for you).
Did you have a USB data stick in? Sometimes that can do it people say.
Does spindle retract and shut off?
Blow out keyboard and all USB connections and if you can try swapping out mouse/keyboard(caused similar for me just before they died) if using a USB hub--try without.
Aaron's having issues and Jeff gave good advice--dig deep for software settings.
Any file? or specific files?
Is the time into the file when it stops similar? If so, it's probably a setting.
Let us know what it was, when you find solution.
Good luck,
